01-04-2019 12:22
01-04-2019 12:22
Hi,
I understood that I can change the style of elements one by one by manipulating the *style property*. This is OK, but I was wondering if there is a way to change classes the same way we can do in modern JS. For example:
let myBigBox = document.getElementById("myBigBox");
myBox.classList.add("bigBox");
mybox.classList.remove("blue");
let myLittleRedBox = document.getElementById("myLittleBox");
myLittleRedBox.classList.add("littleBox");
myLittleRedBox.classList.add("red");I tried to use the *classList* property, but I keep getting the classic *undefined*. Let me know if this is possible. Thanks!
Best Answer01-07-2019 04:16
01-07-2019 04:16
Maybe this will work?
myLittleRedBox.className += " littleBox red";
Best Answer01-08-2019 15:34
01-08-2019 15:34
Unfortunately there's no way to dynamically change an element's class name right now.
01-08-2019 19:02
01-08-2019 19:02
This might work if your case is very simple. There are a few problems with this implementation:
1) You will concatenate more than one class if your event happens more than once;
2) To remove is a pain; You probably have to use something like
myLittleRedBox.className = myLittleRedBox.replace('your-unique-class', '');
// or use regex, splice, etc...Thanks for the suggestion, though. I appreciate it.
Best Answer02-26-2019 03:19
02-26-2019 03:19
You can retrieve the separate classes by string manipulation. It's not very "clean" but it's possible.
Here are the steps you can take (untested, by the top of my head):
var classesAsString = myLittleRedBox.className;
// maybe remove all spaces beforehand with eg this replace solution
// put the classNames in an array by splitting on the comma
var classesSplit = classesAsString.split(",");
// remove class by splicing the classname you want to remove
var indexOfClassToRemove = classesSplit .indexOf("classToRemove"); if (index > -1) { classesSplit.splice(index, 1); }
// build up the new class value by using join
myLittleRedBox.className = classesSplit.join();
Best Answer03-25-2019 07:38
03-25-2019 07:38
Fundamental problem is that neither className or classList are exposed in JS, as JonFitbit already said.
Both give undefined, so nothing is going to work.
This is a real pain - the idea of using SVG for the UI is cool, but not if basic manipulation features are missing.
05-27-2019 08:41
05-27-2019 08:41
Not being able to change a className on an element is a huge pain in the arse and a tragic hole in the SDK capabilities.
01-07-2020 05:55
01-07-2020 05:55
class is now supported in SDK 4, and it works great - you can easily change colours and visibility just by changing the class of the SVG element with the appropriate CSS.
Nice 🙂
Best Answer03-10-2020 18:31
03-10-2020 18:31
Any update on this. Is this possible yet?
Best Answer03-10-2020 18:37
03-10-2020 18:37
https://dev.fitbit.com/blog/2019-12-19-announcing-fitbit-os-sdk-4.1/
