Hello,
I'm developing a clock face and I'm trying to get an image to move offscreen to the left while a new one slides in from the right after one click. Then on a second click, the second image leaves to the right while the original image slides back in from the left. I've tried everything I can think of and then some and I can't get it to work properly. I'm using variations of the following:
index.view:
<svg id="page" pointer-events="visible">
<defs>
<symbol id="first">
<g id="timeOut" transform="translate(0%,0%)" pointer-events="visible">
<image href="image1.png"/>
<animateTransform attributeType="translate" from="0%,0%" to="-200%,0%" begin="click" dur="3" />
<animateTransform attributeType="translate" from="-200%,0%" to="0%,0%" begin="enable" dur="3" />
</g>
</symbol>
<symbol id="second">
<g id="statsOut" transform="translate(300%,0%)" pointer-events="visible">
<image href="image2.png"/>
<animateTransform attributeType="translate" from="300%,0%" to="0%,0%" begin="enable" dur="3" />
<animateTransform attributeType="translate" from="0%,0%" to="300%,0%" begin="click" dur="3" />
</g>
</symbol>
</defs>
<section width="100%" height="100%">
<use id="firstImage" href="#first" width="100%" height="100%" />
</section>
<use id="secondImage" href="#second" width="100%" height="100%" />
</section>
</svg>
index.js
let firstImage = document.getElementById("firstImage");
let secondImage = document.getElementById("secondImage");
let page = document.getElementById("page");
let clockIsVisible = true;
page.onclick = function toggleClock() {
if (clockIsVisible) {
firstImage.animate("click");
secondImage.animate("enable");
} else {
secondImage.animate("click");
firstImage.animate("enable");
clockIsVisible = !clockIsVisible;
Thanks in advance for any help that comes my way.
It looks like you're trying to catch the click event on the very bottom element of the stack. (everything is drawn on top of that)
Instead, try putting a transparent element on the very top, and catch the event there.
<svg>
<!-- snipped for example -->
</section>
</section>
<rect id="touch" class="touch-area" pointer-events="visible" />
</svg>
.touch-area { x: 0; y: 0; width: 100%; height: 100%; opacity: 0; }
const touch = document.getElementById("touch");
touch.addEventListener("click", (evt) => {
console.log("touched");
// start animations
Also, use enable/disable for the actual animation events.
