05-08-2022 18:58
05-08-2022 18:58
Hi everyone,
i'm trying to login to Fitbit studio but I keep getting the below error msg:
SSO: initialising
DevTools failed to load source map: Could not load content for https://corporate-webapps.fitbit.com/fsc-web-client/channels/prod/fsc.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
Is there any fix or workaround for this? I've tried refreshing the page multiple times and read up some forums but nothing seems to work. Pls help!
Best Answer05-10-2022 12:35
05-10-2022 12:35
Actually, I have the same problem. Studio is not starting, and the only thing I can see is:
Best Answer08-03-2022 09:16 - edited 08-03-2022 09:20
Was there ever a fix for this I'm still getting this with Chrome:
Firefox does appear to work however.
Best Answer08-06-2022 13:53
08-06-2022 13:53
Maybe it's a bit late, but try this for a workaround.
First login to www.fitbit.com of community.fitbit.com and then open studio.fitbit.com.
At least it gets you logged in and maybe set to studio.
Usually it works with me.
