02-07-2023 12:16
02-07-2023 12:16
I've built a clockface back in the 2019 and now I'm trying to make some updates but it seems like in SDK v4.3 I can't control the brightness of display anymore:
var flashlightToggle = function() {
if (flash.style.opacity == 0) {
flashlightOn();
} else {
flashlightOff();
var flashlightOn = function() {
flash.style.opacity = 1;
display.autoOff = false;
display.brightnessOverride = 1.0;
var flashlightOff = function() {
flash.style.opacity = 0;
display.autoOff = true;
display.brightnessOverride = undefined;
};In this context, flash is a white rectangle that takes the whole screen, and when triggered, acts like a flashlight and helps me find my way to bed every evening.
Using auto-brightness in situations where you need a flashlight doesn't make sense.
How can I get this functionality back?
Best Answer02-07-2023 12:23
02-07-2023 12:23
The API has changed for .autoOff and brighnessOverride (see here). autoOff will be a problem because of AOD.
02-07-2023 12:23
02-07-2023 12:43
02-07-2023 12:43
Thanks, this was really helpful! Maybe putting display to be always on isn't the best solution. I'll try to set the timer instead.
02-07-2023 13:05
02-07-2023 13:05
I've made an update and even though it doesn't trow an error anymore, it does not work in practice. My "flashlight" is now almost useless 😞
flashlightOn();
} else {
flashlightOff();
//display.brightnessOverride = 1.0;
display.DisplayBrightnessValue = "max";
// display.brightnessOverride = undefined;
display.DisplayBrightnessValue = "normal";
};How can I fix it?!?
Best Answer02-08-2023 00:21
