03-25-2018 15:44
03-25-2018 15:44
Hello,
Considering the multiple warnings in the documentation about images (especially jpg) performance. I tried and confirm that emoji are supported. That would allow me to replace some images with text/emoji.
is that a good or bad idea from a performance perspective ?
Thanks,
Jo
Best Answer03-27-2018 00:45
03-27-2018 00:45
Note that you can't set certain emojis using javascript. For example:
myText.text = "
But you can set it inside the SVG file.
<text>
</text>
Best Answer03-27-2018 05:06
03-27-2018 05:06
I am surprised that it would not work, javascript is supposed to be unicode nowadays. This works in chrome as an example. I can't open the dev studio right now to check why it would not work.
But if that is the case you should be able to reference unicode characters like
let myText = "Thumbsup \u{1F44D}";
Best Answer03-27-2018 06:08
03-27-2018 06:08
@AJoewrote:I am surprised that it would not work, javascript is supposed to be unicode nowadays. This works in chrome as an example. I can't open the dev studio right now to check why it would not work.
You can reference it, but you can't assign it to the text node. It fails here:
myText.text = "\u{1F44D}";
Best Answer03-27-2018 16:01
03-27-2018 16:01
Interesting point @EmTe i had not noticed. i checked and sadly https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/String/fromCodePoin... is not supported even with the polyfill. If needed i would place an emoji in hidden text components to dynamically get/add it where needed.
But back to my original point, i was curious if Fitibit staff could give us guidance on this topic. Is that a good practice or not. I thought they were participating in this forum, are they not ?
01-20-2019 14:06 - edited 01-20-2019 14:33
It would be a nice idea... but from what I can see, the Fitbit OS fonts don't have support for Emoji
I tried the ♡ character and I just got the standard bordered question mark placeholder.
I could not found much info about the fonts ... For example, default is a custom font name Seville http://atipofoundry.com/custom/seville-font-for-fitbit
I found samples of Colfax and Fabrikat on the next but they don't look to support Emoji. https://www.myfonts.com/fonts/hvdfonts/fabrikat/
Best Answer01-20-2019 19:39
01-20-2019 19:39
You can copy and paste the character directly into your "index.gui" file in the SVG.
Best Answer01-21-2019 01:19
01-21-2019 01:19
I did just that, but the character was not visible on the device...at least not on my simulator.
Were you able to show emoji on versa or ionic?
Thanks
Best Answer01-21-2019 19:46
01-21-2019 19:46
@adiroiban wrote:> You can copy and paste the character directly into your "index.gui" file in the SVG.
Thanks
Yes but copying and pasting the character directly into index.gui as if it were any regular character like "!@#$%^&".
