11-02-2018 02:00
11-02-2018 02:00
Hi all,
my app VirtualPartner works well on the Ionic. I implemented GPS functionality and expected that those functions work identically with the Versa when a GPS connection to the companion was established.
Obviously there are some problems. I didn't figure it out by now, but my app first encounters a GPS connection but then gets no location data.
I already found some posts which tell about those problems but didn't find a solution or a suggestions how to handle it.
Is anybody able to help?
Regards
Capitano
11-02-2018 17:45
11-02-2018 17:45
Is it compiled for SDK2 and running on a Versa with Fitbit OS 2.2? That's the only version which supports the Device Geolocation API using connected gps for Versa.
11-03-2018 02:04 - edited 11-03-2018 02:14
ok - thanks for that.
I'm using the latest version of Fitbit studio - I suppose that's always the newest version because there are always auto updates. But I can't find any hint of versioning, but I guess it automatically uses the latest SDK. -- Can I check the SDK version in a compiled app after compiling?
My Versa shows version 32.32.10.15 - because I get no hint of a newer version in the Fitbit app I also suppose that's the newest version.
Because I don't know what was the SDK version exactly with which I built the latest VirtualPartner I'm going to compile it once more and give it a try.
I'll come back to you after that.
Regards
Capitano
11-08-2018 11:25
11-08-2018 12:13
11-08-2018 12:13
So I compiled a new version of the VirtualPartner with the newest Fitbit Studio and the version of my Versa is 32.32.10.15. But GPS tracking with the companion still isn't working.
Is there anything I can do?
Regards
Capitano
11-09-2018 13:09
11-09-2018 13:09
You can factory reset your device to force Fitbit OS 2.2 to install. https://community.fitbit.com/t5/SDK-Development/An-important-update-about-the-rollout-of-Fitbit-OS-2...
11-10-2018 04:33
11-10-2018 04:33
Thanks @JonFitbit.
What''s the version number of the latest OS version, when I want to check it on the Versa?
And which version do I have to use minimal that companion GPS works with third party apps on the Versa?
Regards
Capitano
11-10-2018 08:21
11-10-2018 08:21
@Capitano wrote:
Thanks @JonFitbit.
Regards
Capitano
The Fitbit OS 2.2 version number is x.32.12.19
The Geolocation Companion API can be used with any version, it's the Geolocation Device API which is new in Fitbit OS 2.2 for Versa.
11-18-2018 03:02
11-18-2018 03:02
A guy who wants to use my VirtualPartner with iPhone X and Versa has OS version 32.32.12.19. on the Versa.
I compiled the app about two weeks ago but it still doesn't work. The Versa can't use the GPS of the iPhone.
Has anybody some hints what I/we can do or check?
Regards
Capitano
11-19-2018 05:10
11-19-2018 05:10
I'm not sure if this was answered, but did you verify in your package.json file that you are using SDK Version 2.0? This is specified in a drop-down list in this file and defaults to Version 1.0.
John
11-19-2018 11:24
11-19-2018 11:24
@Drifty26great hint - didn't notice that by now and can't remember that anybody else mentioned that.
Now I sent a build for review with SDK 2.0 and I'm curious it that works...
Thanks
Capitano
11-19-2018 12:05
11-19-2018 12:05
@JonFitbit mentioned this in the first reply, but it wasn't explicit what needed to be changed.
Hopefully this will work.
John
11-19-2018 12:34
11-19-2018 12:34
That's right - but I didn't know that I had to select it in the package.json...
