Hi,
I have a VirtualTileList in which I want to update the items frequently. The list.redraw() seems to not do anything.
Here is my index.js, where for the sake of this example I want to update every tile with the current timestamp. The style.css and index.gui are the ones from the VirtualTileList example.
import document from "document";
let VTList = document.getElementById("my-list");
let NUM_ELEMS = 100;
VTList.delegate = {
getTileInfo: function(index) {
return {
type: "my-pool",
value: "Menu item",
index: index
configureTile: function(tile, info) {
if (info.type == "my-pool") {
tile.getElementById("text").text = `${Date.now()}`;
let touch = tile.getElementById("touch-me");
touch.onclick = evt => {
console.log(`touched: ${info.index}`);
// VTList.length must be set AFTER VTList.delegate
VTList.length = NUM_ELEMS;
function callback(timestamp) {
// Perform animation frame logic here
VTList.redraw()
// Request next frame
requestAnimationFrame(callback);
What am I doing wrong?
Best AnswerHi tik27,
So I tried changing the update function, to set the length of the list.
if (VTList.length == NUM_ELEMS) {
VTList.length = NUM_ELEMS-1;
} else {
VTList.redraw()
}The content is now updated correctly, but every time the length is updated, it scrolls to the top, and since I am constantly updating it, the list is esentially stuck at the top.
There is a setPosition API that you might want to try out?
See https://dev.fitbit.com/build/reference/device-api/document/
Best AnswerWhat do you mean? The VirtualTileList has no setPosition method. The documentation you linked shows setPosition only for the ScrollIndicatorElement.
Sorry, but I have to summon you @JonFitbit. Please shed some light here.
Apparently simply changing the VTList.length is all that's needed in order to force a redraw; calling VTList.redraw() isn't needed at all! Of course, this does always force the display back to the top of the list as well. 😞 I think I'm going to deal with by using "onmousedown" and "onmouseup" events to say, "if you touch on a list item for more than 1 second (for example), it will be moved to the top". Not as nice as the tile list reorder functionality, but usable.
