Is there a way to receive logs from a customer using my watchface? They claim that my watchface is causing the Versa to continually reboot and I do not see any issues with my program nor did I find any issues while I was testing for several weeks.
Best AnswerGood question. The watchface I developed is rebooting my Versa left and right, and I cannot imagine why.
When I'm connected to the dev server, logs are not helping me. What I'd like to see is a core-dump.
In any case, I suspect that getting logs from an arbitrary user introduces an additional set of complications.
The only way I can think of is to modify the code to store your logs in a local file on the watch (as it logs them), and add a button that your user can click to send those stored logs to the companion app, and from there to a server that you control.
But if there is an officially supported way to do this kind of thing, that would be most helpful.
There shouldn't be a way for your app to crash the device. I'd recommend a few things:
1. Ask them to try one of the Fitbit clocks and confirm that the device isn't restarting.
2. If it's definitely just your clock face, then they should contact customer support.
