1. Where does the API gets its weather information from?
It seems to produce a different result from the weather app on the watch.
2. Where do you set the the temperature units?
It seems to only show Celsius.
3. How can you make it get the current weather?
it seems to be 30 minutes or more behind the current situation.
4. How do you get the correct weather conditions?
It seems to return random results (on the watch).
5. Is it possible to set cities, and if so where?
