Hello,
https://github.com/gregoiresage/fitbit-weather - cannot make it to refresh on the device. Using the simulator the location is not updated.
Anyone had similar issues with the module?
Thanks.
Thanks Jon. Appropriate permissions: internet and location are granted. Still cannot make it work on a device.
Best AnswerYou could try to fetch the weather more often (getting fresh data every 10 minutes or so). Also which weather provider are you using?
Kind Regards
Dominik
