12-18-2022 06:51
12-18-2022 06:51
I see people using jsx files in Fitbit studio. How do I change from js to jsx in Fitbit studio?
Best Answer12-18-2022 10:32
12-18-2022 11:45
12-18-2022 11:45
Thanks! is There any jsx guides in Fitbit developer I'm missing?
Best Answer12-18-2022 12:34
12-19-2022 00:18
12-19-2022 00:18
...and this.
Best Answer12-19-2022 02:48
12-19-2022 02:48
Hi, just to clarify: you can't write an entire fitbit app in React.
There is only a subset of react used in the companion-structure to define a limited set of components, which are described in the documentation. Everything else needs to be JS/TS.
