10-03-2017 07:22 - edited 10-03-2017 07:32
Hi all,
Getting an error when trying to sync a card to the watch...the setup otherwise is fine (bank verifies card) but I get an error on sync. I was trying to determine if this could be an issue with the dev firmware or if something else is causing the issue.
Anyone else with the dev firmware try to add a card to Wallet?
Best Answer10-03-2017 08:31
10-03-2017 08:31
Yeah, I had an issue last night. It said I needed to update the firmware, but the update didn't show up for download until later in the evening.
If you're having a different issue, make sure your card is supported (I added an Amex)
10-03-2017 08:31
Best Answer10-03-2017 14:20
10-03-2017 14:20
Just got the beta 1.2 dev firmware...fixed the issue right up. Thanks.
10-04-2017 09:32 - edited 10-04-2017 09:32
What firmware update? I'm having the same problem and I contacted AMEX to make sure I'm properly enrolled.
27.25.16.7
Best Answer10-04-2017 10:00 - edited 10-04-2017 10:01
The dev firmware 27.30.3.2
It seems like those with the regular firmware (which I believe you have the most recent number of) have not experienced this issue (from what I saw on the other forum, anyway).
Best Answer10-04-2017 13:21
10-04-2017 13:21
27.25.16.7
Please don't install the developer firmware, it's beta software intended for development purposes only. If you're having difficulties I would suggest the Ionic Forum for assistance.
Best Answer10-04-2017 16:18
10-04-2017 16:18
So while poking around apparently I registered on the Fitbit studio and keep getting prompted to update to the beta firmware. Is there a way to unregister that I simply can't find?
Best Answer10-04-2017 17:02
10-04-2017 17:02
At this time, it is not possible to opt out of receiving the beta firmware once you have registered as a developer.
You'll need to ignore the update for now.
Best Answer10-04-2017 18:19
10-04-2017 18:19
What do you do if you already have the developer firmware installed?
Best Answer10-04-2017 19:56
10-04-2017 19:56
From my understanding you're stuck with it until it is no longer in beta. If there isn't a way to opt out I'd doubt there is a way to force a down grade.
