12-29-2017 19:29
12-29-2017 19:29
I want to retrieve Google News Headlines and display them on Ionic and because Fitbit SDK can handle JSON, I'm going to rertrieve RSS feed in JSON format through YQL service.
I tested the following URL on Edge, IE11 and Chrome and the result was what I wanted.
https://query.yahooapis.com/v1/public/yql?q=select%20title%20from%20rss%20where%20url%3D%22https%3A%2F%2Fnews.google.com%2Fnews%2Frss%2F%3Fned%3Djp%26hl%3Dja%22&format=json
But when I pass the URL to fetch() API like this,
var FEED_URL = "https://query.yahooapis.com/v1/public/yql?q=select%20title%20from%20rss%20where%20url%3D%22https%3A%2F%2Fnews.google.com%2Fnews%2Frss%2F%3Fned%3Djp%26hl%3Dja%22&format=json";
fetch(FEED_URL) .then(function (response) { response.text() .then(function(data) { console.log("Data: " + data); }); });
I cannot retrieve RSS feed and console.log() shows:
Data: {"error":{"lang":"en-US","description":"Query syntax error(s) [line 1:73 mismatched character ' ' expecting '\"']"}}
How do I fix my code?
12-31-2017 05:08 - edited 01-01-2018 05:58
Problem solved.
I changed form sending method to POST, and it works fine.
Fixed code is:
var YQL_URL = "https://query.yahooapis.com/v1/public/yql"; var GNEWS_FEED_URL = "https://news.google.com/news/rss/?ned=jp&hl=ja"; function urlEncodePost(object) { let fBody = []; for (let prop in object) { let key = encodeURIComponent(prop); let value = encodeURIComponent(object[prop]); fBody.push(key + "=" + value); } fBody = fBody.join("&"); return fBody; }; function fetchNews() { fetch(YQL_URL, { method: "POST", headers: { "Accept": "application/json", "Content-Type": "application/x-www-form-urlencoded" }, body: urlEncodePost({ "q": "select title from rss where url=\"" + GNEWS_FEED_URL + "\"", "format": "json" }) }) .then(function (response) { response.text() .then(function(data) { console.log("Data: " + data); }); }); };
Problem solved.
Fixed code is:
