12-29-2017 19:29
12-29-2017 19:29
I want to retrieve Google News Headlines and display them on Ionic and because Fitbit SDK can handle JSON, I'm going to rertrieve RSS feed in JSON format through YQL service.
I tested the following URL on Edge, IE11 and Chrome and the result was what I wanted.
https://query.yahooapis.com/v1/public/yql?q=select%20title%20from%20rss%20where%20url%3D%22https%3A%2F%2Fnews.google.com%2Fnews%2Frss%2F%3Fned%3Djp%26hl%3Dja%22&format=json
But when I pass the URL to fetch() API like this,
var FEED_URL = "https://query.yahooapis.com/v1/public/yql?q=select%20title%20from%20rss%20where%20url%3D%22https%3A%2F%2Fnews.google.com%2Fnews%2Frss%2F%3Fned%3Djp%26hl%3Dja%22&format=json";
fetch(FEED_URL) .then(function (response) { response.text() .then(function(data) { console.log("Data: " + data); }); });
I cannot retrieve RSS feed and console.log() shows:
Data: {"error":{"lang":"en-US","description":"Query syntax error(s) [line 1:73 mismatched character ' ' expecting '\"']"}}How do I fix my code?
12-31-2017 05:08 - edited 01-01-2018 05:58
Problem solved.
I changed form sending method to POST, and it works fine.
Fixed code is:
var YQL_URL = "https://query.yahooapis.com/v1/public/yql";
var GNEWS_FEED_URL = "https://news.google.com/news/rss/?ned=jp&hl=ja";
function urlEncodePost(object) {
let fBody = [];
for (let prop in object) {
let key = encodeURIComponent(prop);
let value = encodeURIComponent(object[prop]);
fBody.push(key + "=" + value);
fBody = fBody.join("&");
return fBody;
function fetchNews() {
fetch(YQL_URL, {
method: "POST",
headers: {
"Accept": "application/json",
"Content-Type": "application/x-www-form-urlencoded"
body: urlEncodePost({
"q": "select title from rss where url=\"" + GNEWS_FEED_URL + "\"",
"format": "json"
response.text()
Best Answer12-31-2017 05:08 - edited 01-01-2018 05:58
Problem solved.
Fixed code is:
let fBody = [];
return fBody;
fetch(YQL_URL, {
method: "POST",
headers: {
"format": "json"
response.text()
