11-03-2022 08:09
11-03-2022 08:09
To build and install my project using CLI, I need to run the command "npx fitbit" after successfully running "npx fitbit-build". But if I run the command "npx fitbit" in either the CLI or Visual Studio it says "No login information, starting login...".
At this point, a windows should open where I can enter my login credentials to continue, but it doesn't. It also does not give any errors.
I can't find anything online about this issue, so can someone help me with this?
11-09-2022 13:03
11-09-2022 13:03
I tried reverting back to node 16, but that also does not change anything.
I tried doing it on an ubuntu VM and that seems to work. This is not really an answer to my question of this form, but this will do for me for now.
I guess this is just a very specific bug for my case.
Thx everyone for your time and help!
11-03-2022 12:04
11-03-2022 12:04
It should open a web browser window or tab. If your browser is open, check it.
11-04-2022 02:10
11-04-2022 02:10
Thx Peter for your answer, but unfortunately the login window also does not appear in a browser tab that is already open. I also tried closing all browsers and running the command again but that also had no effect. Running Visual Studio as administrator does not do anything either.
11-04-2022 02:45
11-04-2022 02:45
if you've got the correct fitbit dependencies in your package.JSON you could try removing the node_modules folder and reinstall npm i
11-09-2022 05:24
11-09-2022 05:24
Hello Barbara, thx for your answer.
In my package.JSON file are the newest fitbit dependencies (fitbit sdk 6.1.0 and fitbit sdk-cli 1.7.3).
Still after removing the node_modules folder and reinstalling npm, it shows the same behaviour.
I also followed the tutorial on https://dev.fitbit.com/build/guides/command-line-interface/ again from the start with all preriquisites, but it is still the same.
Is there maybe another way to provide the login information, so the command "npx fitbit" does not have to open a window?
11-09-2022 06:24
11-09-2022 06:40 - edited 11-09-2022 06:40
I did not run those commands because when I create a new project from the command line, they are already in the package.JSON file automatically.
11-09-2022 07:23
11-09-2022 07:23
oh... yeah, but I think you'd need to install them (??) at least I do. But might be differently as I set up differently for typescript.
I really think you should try that. wouldn't do any harm if it was not that
11-09-2022 07:31
11-09-2022 07:31
When I run the commands, it says that they are up to date. Unfortunately it does not make any difference.
11-09-2022 07:37
11-09-2022 07:37
11-09-2022 07:45
11-09-2022 07:45
...and sorry for only providing guesses. It's so long since I installed it. But I remember it took me ages to get it running.
11-09-2022 12:30
11-09-2022 12:30
The problem is that it does not launch a browser at all. I can try changing my standard browser to see if that makes a difference.
11-09-2022 12:36
11-09-2022 12:36
There's a TINY chance that it's related to node version. I've never had much success with node 18; I'm using 16.
I also have frequent battles with keytar, which requires native code despite living in node_modules. However, if you were having keytar build problems, that should show up during npm i.
11-09-2022 13:03
11-09-2022 13:03
