I have had a couple of reports that the heart rate is not displaying on the clock face i made.
They are saying they see Null or the 2 dashes i have set which is when the timestamp is the same as the previous reading. here is my code:
const hrm = new HeartRateSensor();
hrm.start();
hrm.onreading = function() {
if (hrm.timestamp === lastReading) {
heartRate.text = "--";
} else {
heartRate.text = hrm.heartRate;
let bpm = user.heartRateZone(hrm.heartRate || 0);
let hrmi = document.getElementById("heartRateImage");
if (bpm === "out-of-range") {
//console.log('out of range ----');
hrmi.href = "icons/heart_open.png";
} else {
//console.log('in range');
hrmi.href = "icons/heart_solid.png";
lastReading = hrm.timestamp;
//stop heart monitor if screen is off
display.onchange = function() {
if (display.on) {
//console.log('screen on');
hrm.start();
hrm.onreading();
} else {
//console.log('screen off');
hrm.stop();
}I'm sure my code is pretty standard ? would it be better to not set the heart sensor as a constant ?
I don't think you should be calling onreading() manually. Other than that, it looks ok.
thanks Jon, i had that as when i was testing it on the simulator i had to manually move the heart rate up on the scale. i assume on the watch it should send a responce so will trigger the change. ill remove it and re-submit it and see if that helps the user.
thanks!
