06-13-2018 11:29
06-13-2018 11:29
Hi,
The below html code is here "https://dev.fitbit.com/getting-started/".
<image href="myimage.jpg" load="sync" />What is the use of load attribute in <image> tag?
Thanks,
Bharath
Best Answer06-15-2018 07:48
06-15-2018 07:48
This is from the SDK Guide
"Note: load="sync" tells the system to use a separate thread when loading the image. This reduces the load time, and can help if you're seeing images ficker on load."
06-15-2018 07:48
06-15-2018 07:48
