Hi guys,
I've been searching the docs and the channels but I can't seem to find an example of the marquee component.
Could someone share how they've been using it?
We are working on updating the documentation and the UI Component marquee is part of it.
In the meantime, this is how you can use it. First add the import statement in your widgets.gui file
<link rel="import" href="/mnt/sysassets/widgets/marquee_text_widget.gui" />
And in the gui file you want to display the marquee, you can use it like this
<svg>
<use href='#marquee-text' font-size='32' width='100%' height='100%' fill='white'>
<set href='group/text' attributeName='text-buffer' to='Bacon ipsum dolor amet sausage prosciutto tongue turducken tail.' />
</use>
</use>
</svg>
<svg>
</use>
</use>
</svg>
is there maybe an option to control the speed? It is moving kinda fast by default, not sure it would fit my style
Try adding the `value` attribute to the `<use>`.
<use value="500" ....
How do you change the text inside the Marquee programmatically? Where does the 'id' go and what attribute do you change in the javascript?
Best Answer<use href='#marquee-text' id="address_address" class="h1 address_address" font-size="70" x="0" fill="mediumpurple" value="40">
</use>
title.text = 'someText';
If you just select the marquee like any other element by id you can set the text val
Is there any way to make it pause the marquee after it finishes a scroll for a few seconds? I tried disabling; but that leaves it where ever it stops, and then resets it on enable.
Best AnswerIt looks like it would be a pain. Clearing and resetting the text puts it back at the beginning; but there doesn't seem be a way to see where along the scroll it is; su you have to time it and then on an interval disable and re-set the text and then re-enable it.
Best AnswerSetting the speed in the SVG is fine, it can also be done in a linked stylesheet. But what I can't seem to do is change the speed programmatically. I've tried element.style.value="120", element.value="120", element.setAttribute("value","120") -- and tried both numbers and strings. element.value generates an error if I don't provide a number - but it doesn't seem to take effect.
Best AnswerIt is very well possible, that this value is hardcoded in the underlying symbol, so every change you make would be overwritten by that one. Just a guess. (To be sure you could check the symbol in the simulator-files.)
Best AnswerI suspect that .value isn't implemented in the JS bindings.
As a kludge, you can change .class at runtime. You'll need a separate CSS rule for each .class, and just put the value in each one.
I don't know how 'dynamic' this will be; eg, if you change the class, the new value may not take effect without some messing around (or ever). I know it works at least the first time!
Obviously this will be a bit limiting if you want heaps of different values.
Best AnswerPeter,
Thanks. But I'm curious about your statement that "...it works at least the first time" - I've been unable to make it change at all.
I've attempted to change the class using e.className = "newClass", e.className.basVal = "newClass", and e.setAttributes("class","newClass"). None of these work at all. What method did you use?
Joey
Best AnswerIf value isn't exposed and class doesn't work for switching, you could perhaps try a workaround by grouping the marquee and animate additionally or alternatively.
Best AnswerBarbara,
I tried those approaches, but none worked dynamically. The only solution I found (and chose not to implement) was to have 3 or 4 speeds defines on duplicate marquees which were selectively hidden. Not so much fun, that. For the time being I'm just going to pick a good rate and hard-code it.
J.
