11-08-2020 12:33
11-08-2020 12:33
Why is the ontick skipping seconds ?
// timeColonEl.text = ":";
timeColonEl.style.display = 'inline';
export function animateColon()
if(timeColonEl.style.display == 'none')
else
timeColonEl.style.display = 'none';
export function getElement(type){
return document.getElementById(device.screen.width + "-" + type)
//Time Draw - START
export function drawTime(now) {
setHours(now);
setMinutes(now);
setSeconds(now);
export function setSeconds(now){
if (showSeconds)
timeSecEl.style.display= 'inline';
timeSecEl.text = zeroPad(now.getSeconds());
else
timeSecEl.style.display= 'none';
export function setMinutes(now){
timeMinuteEl.text = zeroPad(now.getMinutes());
export function setHours(now) {
var hours = now.getHours();
let clockFormat = timeFormat;
if(timeFormat === "auto")
clockFormat = preferences.clockDisplay;
if (clockFormat === "12h") {
// 12h format
if (isAmPm) {
if (hours < 12) {
timeAmPmEl.text = " AM";
} else {
timeAmPmEl.text = " PM";
timeAmPmEl.style.display= 'inline';
else
timeAmPmEl.style.display= 'none';
if (hours === 0)
hours = 12;
} else if (hours > 12) {
hours = hours - 12;
} else {
// 24h format
if(showLeadingZero)
timeHourEl.text = zeroPad(hours);
else
timeHourEl.text = hours;
//Time Draw - END
export function zeroPad(i) {
if (i < 10) {
i = "0" + i;
return i;
clock.ontick = (evt) => {
time.drawTime(evt.date);
Best Answer11-08-2020 12:27
11-08-2020 12:27
Hi, I saw that the ontick function is randomly skipping seconds.
Can anyone else check ?
code:
else
//Time Draw - START
setHours(now);
setMinutes(now);
setSeconds(now);
if (showSeconds)
else
// 12h format
if (isAmPm) {
if (hours < 12) {
} else {
else
if (hours === 0)
hours = 12;
hours = hours - 12;
} else {
// 24h format
if(showLeadingZero)
else
//Time Draw - END
if (i < 10) {
i = "0" + i;
return i;
Best Answer11-08-2020 12:50
11-08-2020 12:50
That happens routinely on the simulator. Have you observed it on a physical watch?
