Hi there,
I am trying to install an app on OS simulator , I follow the instruction here :
https://dev.fitbit.com/getting-started/
3.Installing
If you're using the simulator, you just need to launch it and login with your Fitbit account.
If you're using a Fitbit device, you need to enable the Developer Bridge. On the watch, go to Settings and tap Developer Bridge, then wait until it says Connected to Server.
The simulator or device should now be connected to the developer bridge. Next you need to select it from the devices toolbar within Fitbit Studio. Once you see a green indicator, you can click Run to launch the clock face on your device.
I am confused that do I need to just launch the simulator and login?
or
should I also connect the simulator to the developer bridge?
I launch the simulator and login with same account , but nothing happens , no green indicator , no device to select!
please advice what should I do to install my app on simulator?
tnx
