02-20-2019 01:05
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-20-2019 01:05
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
Hi there,
I am trying to install an app on OS simulator , I follow the instruction here :
https://dev.fitbit.com/getting-started/
3.Installing
If you're using the simulator, you just need to launch it and login with your Fitbit account.
If you're using a Fitbit device, you need to enable the Developer Bridge. On the watch, go to Settings and tap Developer Bridge, then wait until it says Connected to Server.
The simulator or device should now be connected to the developer bridge. Next you need to select it from the devices toolbar within Fitbit Studio. Once you see a green indicator, you can click Run to launch the clock face on your device.
I am confused that do I need to just launch the simulator and login?
or
should I also connect the simulator to the developer bridge?
I launch the simulator and login with same account , but nothing happens , no green indicator , no device to select!
please advice what should I do to install my app on simulator?
tnx
02-20-2019 00:59
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-20-2019 00:59
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi there,
3.Installing
- If you're using the simulator, you just need to launch it and login with your Fitbit account.
- If you're using a Fitbit device, you need to enable the Developer Bridge. On the watch, go to Settings and tap Developer Bridge, then wait until it says Connected to Server.
- The simulator or device should now be connected to the developer bridge. Next you need to select it from the devices toolbar within Fitbit Studio. Once you see a green indicator, you can click Run to launch the clock face on your device.
I am confused that
or
please advice what should I do to use the simulator?
tnx
and
02-20-2019 11:02
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-20-2019 11:02
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
When you launch the simulator, it automatically connects to the developer bridge and simulates a phone and a Fitbit device. If you go to the "settings" tab in the sim, you should see that it's connected.
If you're connected then you should be able to select those simulated devices in Fitbit Studio.
If the sim is connected, but Studio doesn't see the devices after a refresh, then ensure you're logged in with the same account in Studio and the simulator. You can log out of www.fitbit.com and simulator, then try again.
02-20-2019 11:14
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-20-2019 11:14
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I launched the Sim but in Setting tab I see :
* Device bridge is disconnected
* Companion bridge is disconnected
I log in to both Sim and Studio with same account
I did logging out and in again , but still I get the same Disconnected message in Setting tab...
02-20-2019 12:46
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-20-2019 12:46
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Have you tried quitting the simulator and starting it again?
Can you also collect logs and send them to me via a private message?
Logs:
OS X: ~/Library/Logs/Fitbit OS Simulator/log.log
Windows: %USERPROFILE%\AppData\Roaming\Fitbit OS Simulator\log.log
02-20-2019 23:16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-20-2019 23:16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
yes , I have tried quitting it and start again...
sure , I sent it
tnx
02-23-2019 05:13
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-23-2019 05:13
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hi there,
I wondered if you get the private message that I sent, containing log.log events?
02-27-2019 23:58
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-27-2019 23:58
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
hi
did you find any solution to help me connect simulator to studio?
03-14-2019 13:24
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
03-14-2019 13:24
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Sorry for the delay. From the logs it looks like you don’t have working network/DNS or something. Is this running in a virtual machine or could there be a firewall blocking traffic?
09-04-2019 06:40
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
09-04-2019 06:40
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I have the same problem.
I'm not running in a virtual machine. I have a working internet access.
The simulator (even after reboot and relog) always shows both disconnected messages.
My watch has a connection error 1006.
Any advice?
06-28-2021 14:39
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2021 14:39
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I am also having the same problem.
Has anyone found a solution?
06-28-2021 14:47
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2021 14:47
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Something is broken at the moment, I think. Wait.
Gondwana Software
06-28-2021 15:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2021 15:42
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
It's on the FitBit end, I just moved the moon to get things to work.. nothing.. and looks like multiple of us are having the same issue.
So now we all wait...
Doing other productive things.... guess I'll go make use of this watch hah..
06-28-2021 15:44
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
06-28-2021 15:44
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
As soon as I sent that.. things connected.. not sure if it'll stay up or not but, I'm green again on both.
11-17-2021 23:53
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-17-2021 23:53
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Hey,
I am trying to test my app on the Fitbit simulator. I don't have a device right now.
I am not able to connect the device bridge. Can you suggest what steps do I need to follow?
11-18-2021 00:21
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-18-2021 00:21
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Have you authorised your Fitbit account for development? I think you need a real device to do this.
Gondwana Software
11-18-2021 15:32
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-18-2021 15:32
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I am having the same issue. I have used the simulator before, but it no longer connects. Anyone know of a solution?
11-18-2021 23:00 - edited 11-21-2021 07:39
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
There is a problem with the certificate, which if you check the settings tab in the OS Simulator shows "device bridge is disconnected".
If this is your problem try the work around posted here
Which is you have to copy the "cacert.pem" [given in the post] to each of the OS Simulator watches folders.
11-21-2021 07:19
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-21-2021 07:19
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Has anyone managed to solve this? I can see the simulator for the phone but not the device. Then in the Fitbit Simulator all I see is this error:
It's easier to develop with the simulator than loading it on to my device since hovering on the simulator shows me the coordinates of the screen.
Has anyone managed to fix this?
11-21-2021 07:41
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
11-21-2021 07:41
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
