09-06-2018 22:45
09-06-2018 22:45
Recently, I'm developing clock faces for fitbit (both Ionic and Versa), and received a few reports about the calories display is different from the Today stats and the fitbit app. (Would happen on Ionic or Versa) E.g. the Today stat shows calories burned 1940 but the clock face shows 1636; the Fitbit states 400+ calories, but the clock face only states about 200+ calories.
The users confirmed they have allowed all the permission the clock face needed and also enabled the all-day sync. Firmware and the fitbit app should be the latest version.
I didn't meet this problem on my Ionic and it looks like a rare case comparing with the other reports/ suggestions I have received.
Similar to the other activity stat, I'm getting from the "user-activity"
import {today} from "user-activity";
Calling "today.local.steps; today.local.calories; today.local.elevationGain; today.local.activeMinutes"
The activity stat will be updated whenever an ontick event occurs.
I have been trying to look into what problem is in my code but due to my limited knowledge, I cannot find any clue for this issue...
So, please help share any of your thoughts regarding to this issue so that I could try fixing the issue.
Let me know if any information is needed for further advise.
Thank you very much!
09-07-2018 00:31
09-07-2018 00:19
09-07-2018 00:19
I've moved your post to the SDK development forum, you will receive a better response here.
09-07-2018 00:31
09-07-2018 00:31
Try using today.adjusted...
09-08-2018 02:32
