03-04-2023 19:04
03-04-2023 19:04
Why does my watch sometimes consume power quickly and sometimes slowly? is it because it has something to do with the frequent disconnection of the iphone Bluetooth connection? Or is there any other reason?
Best Answer03-04-2023 20:51
03-04-2023 20:51
Hi @Darkwhite - the battery life between charges can change for several reasons, firstly if you did exercises and used the GPS, that uses a lot more battery, you may not have noticed that it was on.
If you used Always On or used the watch display for long periods.
As you ask, syncing problems can be another issue where the battery gets used a lot or firmware updates. One way to eliminate this as an issue is to turn off the phone's Bluetooth and see if the watch battery lasts longer.
Lastly if the battery life is constantly short < 2 days there may be a watch fault.
