Accessing Alexa seems so cumbersome. Do I really have to click on apps and scroll down to alexa every time I want to use it? Is there another, shorter, way?
Best AnswerYes from the watch when awake (touch the left button or wrist twist) scroll down, then select the settings gear. Scroll to shortcut and select it, then set up long button press for alexa when set up a long press on the left button will open alexa
Thank you for your help!
