01-28-2024 17:48
01-28-2024 17:48
I had an alarm set when I switched from Sense to Sense 2. I need to change this alarm, but it’s not showing up in the Alarms section. It’s also not showing up in the iPhone app. I set two additional alarms which do show up in the Alarms section. Something extremely odd. When the alarms go off, the two additional ones show up as ORANGE. The alarm that is not showing up is BLUE. I have looked through every screen of the Sense 2 and every setting in the iPhone app and cannot find this other alarm. I need to turn it off. Oh, and I’ve already rebooted the device, did not fix the problem.
Best Answer01-28-2024 23:54
01-28-2024 23:54
Hi @scottnearcincy - if you used Alexa previously or use Alexa it might be set there.
