Hi @Jpy16 - if you haven't initiated a walk as an Exercise you may not have GPS tracking to produce a map.
With the watch display on press the button, choose Exercise, choose Walk or other exercises and Walk, there you can swipe up and set GPS on and other options, and start a walk.
Even then you may not get all the walk if the GPS gets disconnected, which can happen, You will also need to sync the watch after the walk to get the information in the Fitbit App .
