02-13-2024
15:58
05:18
CrisVillaFitbit
02-13-2024
15:58
05:18
CrisVillaFitbit
My Sense 2 tracker is tracker lower calories than my old one. I'm doing same workout. How do I fix this? My height, weight, and age is correct.
Moderator edit: edited title to clarity.
Welcome to the community, @wvufan4-ever.
Thanks for letting me know about this situation in regards to the calories tracked in your Sense 2.
Is the difference between the calories you used to burn and the ones you burn now big? Since this can change, since your body is more used to exercise now, it will burn less and less calories.
Also, I recommend you double checking you're wearing your Sense 2 correctly, just to make sure your Sense 2 tracks the data correctly.
