01-24-2023
20:03
10:13
LizzyFitbit
01-24-2023
20:03
10:13
LizzyFitbit
Is there a way to put the fitbit sense 2 on airplane mode. There is the sleep mode that I use, but is there still the Bluetooth that is working with that mode ?
I would love to put it in airplane mode so i'm not expose to cellular reception 24/7.
Best AnswerI don't know if BT is turned off in sleep mode. Or even if the fitbit app stops sending notifications. The tracker does turn off vibrations and the turn on with wrist movement.
Like all other fitbit Bluetooth can not be turned off
