08-03-2024 04:30
08-03-2024 04:30
Where can I see what clock faces are available on sense 2. Won’t buy if I can’t see options
08-03-2024 07:57
08-03-2024 07:57
Hello @Teresajp and welcome to the Community. I’m sorry, but there isn’t a good way to preview Sense 2 clock faces online. Fitbit has a Clock face Gallery online, but you can’t filter by model. There are hundreds of clock faces available, unless you live in the EEA, where the choice is limited.
If you know someone with a Sense 2 or Versa 4, you can look at clock faces on their Fitbit app.
Laurie | Maryland
08-03-2024 08:07
08-03-2024 08:07
08-03-2024 11:46 - edited 08-03-2024 11:47
Be careful when looking a clock faces. I have a Sense 2 and the clock gallery does show hundreds of clock faces, many of them say “not optimised” when you click on them. In other words, they may or may not work with the Sense 2 or Versa 4. I think they just attached the gallery for the original Sense and the Versa 3 to the Sense 2, so it’s kind of a gamble if most of the clock faces will work, and there’s no way to drill into faces for one specific model.
I think the original Sense is a better tracker and is more reliable. It also has the EDA tracker, just not continuous .
Good Luck!
08-03-2024 13:04
08-03-2024 13:04
Thanks for your helpful advice, I might look into original sense
You would really think they would show you the faces under description.
teresa
08-03-2024 13:30
08-03-2024 13:30
There are literally hundreds of clock faces available, most free but also some paid, so I guess it would be too time consuming for Google to publish them since they are so busy messing up the app.
