Clock faces
Has anyone had issues with their clock face arbitrarily changing? I searched eons to get the one I wanted then it arbitrarily changed yesterday and again today! And now I cannot find the original one I had!
8 REPLIES 8
You should be able to see your last 5 clocks in the app and easily switch back.
From phone app Today screen, battery icon at top left > Sense 2 > Gallery
See your last 5 clocks, tap on any and if you want it, tap "Select".
I know I should be able to see them but the original is GONE!
Hi @Claudiawood - did you try to pull down on the watch face to get to Quick Settings and turn off all the icons? If you get Always On enabled and wrist wake off, you can get a different default clock face.
That was the first thing I tried.
I am just annoyed I can’t find the original because it took me ages to find it.
@Claudiawood - unfortunately if you load a lot of clock faces it's possible that existing ones get overwritten.
In which case from the Gallery tile search for it based on it's criteria.
I only had three or four in the gallery. Never loaded any more. I was wondering if the face I had was deleted or removed by Fitbit, no longer available?
Now I have five, including the two I never downloaded that replaced my original (without me doing it)!
