When using the Walk exercise, the stats screen shows the pace by default. I then have to swipe through the other options to get to the current time.
Is it possible to have it show the current time (or other choice of statistic) by default?
Best Answer@JeffHarlow You can customize the top, middle, and bottom stat for all of the shortcuts in the Exercise app on the Sense 2. Here are my thoughts. The Walk shortcut has Distance as the default top stat and Elapsed time as the bottom. If Short press the button, then open the Exercise app. Choose walk, then swipe up on the screen. If the current time is more important than either distance or elapsed time, make it your top or your bottom stat. It looks like Pace is the default middle stat, because that is at the top of the list of the middle stats you can customize. Sorry, you can't drag those stats to a different order. You can toggle off the things you don't want to see. I toggled off distance and elapsed time in my middle stats, because they are already on the screen. I recommend making the current time your top or bottom stat. Then you won't have to swipe through all your active middle stats.
Laurie | Maryland
