Twice in the last two weeks my steps have gone from 8000 to over 200000, all while on the couch!
My calories aren't counting my BMR so pretty much just counting the exercised portions of my day
Distances are also not tracking. For example, I walked 6km yesterday, worked out, moved for over 12000 step, distance covered - .29km. calories burned 1500 (I'm 6' 220# so on a given day just sitting on my couch I should be burning 1900+?)
I have had charging issues with my Sense. Maybe it's just broken? For as expensive as it was in Canada, getting two years out of the product doesn't seem to be very good?
Best AnswerMy thought is that you will have trouble getting a solution when reporting 3 or 4 problems all at once. You would have a better chance if the next time you encounter a problem, report the specifics of one particular problem so someone can try to figure out what might be causing that. Perhaps that might explain other issues, or perhaps not, but there's a better chance of understanding one problem at a time, rather than 3 or 4 all at once. Just my point of view; unlikely that everything broke and is making everything go crazy.
