Distance tracking in my Sense 2 is very inaccurate. I have multiple other people who walk with a 2 mile loop. Everyone else's devices seem to match the loop length as marked. My Sense 2 is erratic and often off (more) by 20%. Incidentally, this is my second/replacement Sense 2. Earlier one also had the same problem.
Also BTW, I have had multiple generations of Versa before. They were all fine.
I see others have reported the issue with Sens 2 as well, but those have been closed for reply with actually no convincing or eve relevant replies.
Sad!
Hi @WalkingYogi.
Have you tried selecting connected (phone GPS) instead of the built in GPS on the Sense 2? Unfortunately the GPS on the Sense 2 is quite poor due to the placement of the antenna. So you may have a better experience if it piggybacks off of your phones GPS (assuming you have your phone with you).
Hi, I would like to try this 'fix' as using my Sense 2 GPS shows I have covered a certain distance however sometimes doesn't sync the full distance to Strava - I have just googled it but can't see an 'idiots' guide on how to do it, any chance of a link or instruction please to connect to iphone GPS?
Hi @whizzieg @WalkingYogi @Rdrunr2 - there is another option, to not use GPS at all and just go with stride length which if accurate may give a closer result, assuming the distance units are set correctly in App settings.
