Is there a way to edit the elevation required to count a floor. I have read that the elevation is 10ft and doesn't work in my house. If I go up 2 flights of stairs it counts as one floor. I think in my house the distance is 8'.
Best AnswerYou mentioned going down the stairs. Nobody gets credit for going down stairs anyway. It's only going up stairs.
Best AnswerYou cannot edit floor height, but you can try making sure your arms are lowered at the bottom and raising them over your head at the top, artificially add a bit of height to a single flight of stairs.
Hello @Nefarious854 and welcome to the Community. I'm sorry, but you can't change the programming for the altimeter. It's very important that you go up the stairs in a smooth movement and don't hold the handrails. I don't think your distance is 8' or you live in an old house with 7' ceilings.
I used a Fitbit One (worn on torso) for several years and its floor counting was spot on in my house with 8' ceilings. All of my wrist Fitbits have undercounted my floors. I think the altimeter is very, very sensitive. Certain arm movements or holding handrails seem to interfere with floor counting.
Laurie | Maryland
