05-21-2024 13:59 - edited 05-21-2024 22:46
I only have three exercise options to select from on the exercise tab on my Sense 2 watch: bike, walk, run. Under explore tab there is an other exercises tab but it won't let me select it! I wanted to pick treadmill but can't find it or any other exercise options ! Have Fitbit removed them in some update? Please help 🙏
05-21-2024 20:51
05-21-2024 20:51
Hi @Kaydee1207 - as a first step hold the watch button for 10 seconds till it blanks or vibrates and wait for the logo to appear and for it to start.
Then press the button, select Exercise and scroll the list. The most recent ones come to the top.
05-21-2024 22:42
05-21-2024 22:42
Hey, the only options are: bike, walk, run. No other options available. Under explore, there is 'other exercises' tab but it's none responsive. I've shut down and restarted and still the same. Can't even locate the other exercises through the phone app!
05-21-2024 22:57
05-21-2024 22:57
@Kaydee1207 - If it is not working after a restart then a factory reset may be necessary (not without risk) and It is a good idea to make a note of the names of any clocks and any special watch or app settings you use before the factory reset or replacement, if necessary.
05-22-2024 04:36
05-22-2024 04:36
@Kaydee1207 It sounds like you are starting your workout on the app. You need to use the Exercise app on the Sense 2. Short press the button, then tap on Exercise to open the Exercise app.
Laurie | Maryland
05-22-2024 05:59
05-22-2024 05:59
No I'm not. As stated in my or my original post....'I only have three exercise options to select from on the exercise tab on my Sense 2 watch: bike, walk, run"..
05-22-2024 12:56
05-22-2024 12:56
@Kaydee1207 I’m sorry that I misread what you wrote. Are you swiping left/right to your Exercise tile? If you are seeing those three exercises in circular icons, those are quick start shortcuts. Those three are there by default. You can access the other shortcuts by tapping on the All icon below. Or by short pressing the button and selecting the Exercise app. As you use different shortcuts, they will replace those three default shortcuts.
I want to emphasize that they are quick start shortcuts. They are tap and go. You can’t change any settings, like setting a goal.
Laurie | Maryland
