Hi,
I have managed to find 3 or 4 places to change temperature from fahrenheit to celsius. The only place I still see fahrenheit is the main report tile on the app, once inside temperature - it switches to celsius. How do I change that? Everything else is kilometers, meters etc.
Other things I did this morning before it started working is I changed my location from UK to US and back again and I also had an update to the app. But the change only happened after I moved the tile. It may have been coincidence.
I hope you come right!
Best AnswerI have tried removing that tile, moving it around, reopening the app. Nothing seems to work. But at least it seems possible if you managed to get it.
Best AnswerOther things I did this morning before it started working is I changed my location from UK to US and back again and I also had an update to the app. But the change only happened after I moved the tile. It may have been coincidence.
Best AnswerAwesome! I'm glad you came right.
