I have a pixel watch that drains so fast need to charge it every day my Aria was every few days but the Airia scale says it hasn't synced in 80 days even though I've used it multiple times I hope the data is still there I tried their resync it so many times I held the button down and it doesn't do anything. Also, I have the tracker what happens if I enable my phone because it needs to be charged so much will the phone act as a backup? Or will it just double my step?
Best AnswerHello and welcome.
First, let me suggest that when you have m ore than one question, it often helps if you split them into different posts. The reason is that someone might have an answer to one issue but not know about the others; therefore not reply, leaving you with no answer. But if you separate the questions, I think you have a better chance of getting responses to each. Just my suggestion.
As to the pixel watch draining, a day or maybe 2 is normal for the Google Pixel watches, as opposed to the Fitbits which have battery charge lives of several days. You say your Aria was every few days. I'm not sure what you are referring to. I don't know of any watch called Aria.
Hi @bateman7 - what @JohnnyRow says is a good point, especially post the topics in the correct forums too.
The new V4 Fitbit App is known to have numerous problems with syncing which could be causing you issues.
As mentioned the Pixel watch requires regular charging, but it doesn't take too long so adding your phone as an additional step counter will only complicate things further unnecessarily.
You should troubleshoot your Aria scale sync issues separately.
You can always chat via the Fitbit App, Help & support section, Contact Customer support for assistance with that.
