06-15-2023 12:24
06-15-2023 12:24
I recently purchased a Sense 2 (previously had a Sense) and reinstalled the Light clockface by Fitbit. However, not when the screen wakes up, the second hand (red) will momentarily display at the 12 o'clock position before jumping to the correction orientation based on the time. This makes it feel and look really laggy.
I've uninstalled/reinstalled the watch face multiple times, restarted the device (including a factory reset) multiple times, but still no luck. Anyone else running into this issue?
06-17-2023 21:57
06-17-2023 21:57
@fufukatchoo - thanks for the clarification, the new operating system on the Sense 2 is a bit special for some AOD features.
The built-in AOD display is only 24 hr digital but clock faces can have their own version which may have a bug imposed by the operating system.
Faces ported to the Sense 2 (even Fitbit ones) may not have been fully tested, thanks for reporting the issue.
The best way to raise it is to contact the developer in this case chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
06-15-2023 21:09
06-15-2023 21:09
Hi @fufukatchoo - it is probably poor design.
When the display blanks the watch stops, when it comes on it has to catch up, but curious it is only the second hand with the problem.
See what happens if you select Always On or try another clock face.
06-17-2023 21:09
06-17-2023 21:09
So the issue is actually when AOD is switched on (I should've mentioned this in the first post). Based on what you said I turned AOD off and interestingly the issue doesn't occur when the screen goes completely on/off after the timeout. When it wakes up, the second hand is where it should be and continues ticking from there.
This didn't occur on the Sense so I'm surprised the newer device is having issues with the same watchface.
06-17-2023 21:57
06-17-2023 21:57
