05-19-2023
07:47
11:19
AndreaFitbit
05-19-2023
07:47
11:19
AndreaFitbit
I got a Fitbit Sense 2 last November. The battery life had been pretty good. Sometimes I could go two days or longer without charging it. Now the past couple days it is almost totally out of power at the end of the day. Today it was at 8%. What could be going on?
Best AnswerHi @mandarbank.
Is it possible that you have changed a setting on the device? AOD (always on display), SpO2 and cEDA are all big battery consumers. If you aren't using any of these it's worth checking again to see if any have been turned back on.
Also some 3rd party clock faces consume more battery than the stock Fitbit faces. Have you changed your clock face recently?
