10-26-2024 05:42
10-26-2024 05:42
My fitbit sense 2 is only receiving phone call notifications- does not receive text messages. Have tried all suggestions online- checked bluetooth, fitbit app, deleted app, shut down phone...etc. Did see one suggestion that says on the fitbit device go to settings, vibration & audio and then to make sure "allow call and text" is enabled. I do not have that option on my fitbit device under vibration and audio. My only choices under vibration and audio are - vibration and microphone??
Best Answer10-26-2024 16:17
10-26-2024 16:17
Same here, noticed it a couple days ago.
Best Answer10-26-2024 20:52
10-26-2024 20:52
Hi @LaurieAC @Stephmarie83 - it is probably due to a bug in the Fitbit App and your watch not syncing, and can only be resolved by Google, do not factory reset the watch because a second bug can stop you reinstalling it.
Best Answer10-26-2024 21:25
10-26-2024 21:25
I have the same problem. I can get phone calls, but not text messages.
Best Answer10-27-2024 03:49
10-27-2024 03:49
Best Answer10-27-2024 12:50
10-27-2024 12:50
