11-28-2025
15:02
18:36
EstuardoFitbit
11-28-2025
15:02
18:36
EstuardoFitbit
On my Fitbit Sense 2 there is only Alexa and no Google Assistant anymore.
Normally on my Pixel 8a I mostly use the new Gemini.
Is it possible to use it also on my Fitbit Watch? Is it possible that an update will activate it in near future?
Fitbit is Google so an assistant from Google should work and no Alexa. Don't like Alexa ...
Hey there @GeoLemmi, it is nice to see a new face around
I'm grateful for you reaching out and sharing your feedback about the Voice Assistant. Your input helps us understand what's working well and what needs improvement.
While having Gemini as a voice assistant is not possible at the moment, you can always share your ideas in our Product Feedback board. Your suggestions can be upvoted by other users, making them more likely to be seen by our team.
Thanks again for your feedback! We appreciate your help in making Fitbit even better.
Hi @GeoLemmi - Gemini inclusion for Fitbit watches is a good question.
Older watches had both Google Assistant and Alexa and only on the Sense 2 and Versa 4 was Google Assistant not implemented.
Google are threatening to remove the Assistant from the older watches too which is the opposite of what you would expect for a voice assistant, which would be invoking Gemini in it's place as the voice interface mechanism is already implemented and then adding it to the later watches.
However as Google are unfortunately trying to phase out Fitbit smart watches by removing stuff such as music support and GA on the older watches, any expectations of improvements or continuity of service is unlikely to get implemented.
Irgendwie scheint aber in der neuen Fitbit App sowas wie Gemini enthalten zu sein. Vielleicht werden wir überrascht und es kommt über den Weg zurück.
