09-20-2022 16:28
09-20-2022 16:28
My fitbit Sense 2 is giving me degrees in Celsius. How can I change that to Fahrenheit?
09-20-2022 20:05
09-20-2022 20:05
Hi @blueskysunnyday - it's explained here How to change Temperature - for Weather, Centigrade - Fahrenheit, Sense
Best Answer09-21-2022 19:58
09-21-2022 19:58
that may be very simple
Best Answer09-26-2022 18:09
09-26-2022 18:09
How do I change the hourly settings from 24 hours to 12 hour?
Best Answer09-26-2022 19:28
09-26-2022 19:28
Hi @SpiritMommaLeah - it's in your web account profile settings clock display time, click submit at the bottom and sync your watch.
Best Answer09-27-2022 16:43
09-27-2022 16:43
My regular clock is in 12 hour format, and my settings reflect that. But for some reason the weather app, when I che k the "hourly weather" is in 24 hour format.
Best Answer11-24-2022 06:25
11-24-2022 06:25
For weather the fix is in the app click on your profile picture, then click on your sense 2 picture, then click on gallery, in the new window click apps, then choose weather, in that window choose settings. Its there that you change the units for weather you can also add o location.
