03-27-2024 13:31
03-27-2024 13:31
During resting the heart rate seems to work fine. When exercising the heart rate will not go higher that 90 or 100 (Is around 150 normally when checking at the GYM with other machines or watches)
I have worn the band in every possible way as described in other topics in the forum. It does not work. Any solution for this?
I have the
Best Answer03-27-2024 21:13
03-27-2024 21:13
Hi @BruceAnderson - it is a common problem with the heart rate sensor on this watch type.
It seems to depend on type of exercise and the person, for some it under reads and for others over reads (mine can read almost double).
03-28-2024 06:18
03-28-2024 06:18
Having same issue since i got the watch in October. Called support several times and nothing has helped. Now lately it is not tracking my sleep cycles. Please update is you get any good feedback or get something that fixes it.
