11-14-2024 08:49
11-14-2024 08:49
I added a manual exercise today. 9.5Km for a spin bike. It isn't adding to the total miles.
I've restarted the app, disconnected the watch from Bluetooth etc, all the usual faff required for FitBit now.
Nothing has worked. Any ideas or shall I just finally throw the towel in?
Best Answer11-15-2024 08:30
11-15-2024 08:30
@RebPet Daily distance has always been calculated from step based activities. Distances from biking and swimming have never been added.
Laurie | Maryland
Best Answer11-15-2024 09:24
11-15-2024 09:24
Best Answer11-15-2024 11:01
11-15-2024 11:01
@RebPet Your treadmill is step based. Fitbit has never added distance from a bike based activity, indoors or outdoors.
Manually adding an activity can mean different things to different people. If you are tapping on the green + button, then using the Manually log option, then you should only do this if you aren't wearing your Fitbit at the time. If you are wearing your Fitbit, then you should use the Exercise app on your Fitbit with the appropriate exercise shortcut.
Laurie | Maryland
Best Answer11-15-2024 12:21
11-15-2024 12:21
Best Answer11-16-2024 04:47
11-16-2024 04:47
@RebPet Treadmill distance is an issue for all users, even different brands of fitness trackers. A treadmill measures distance from the belt movement. Its measurement can be off if it isn't maintained properly.
Your Fitbit measures distance using a steps x stride length equation. Fitbit uses your walking stride length in the treadmill shortcut. Your actual stride length on a treadmill will depend on your pace and if you add an incline. When you run on a treadmill, Fitbit recommends using the Run shortcut with GPS off.
If you use the Manual log feature while wearing your Fitbit, you create incorrect data. Treadmill data is especially problematic. Every bit of data on a Fitbit is an estimate. I don't micromanage my treadmill data.
There is another small point to keep in mind. Manually added distance doesn't count towards lifetime distance badges. If you keep an eye on your badges, you won't get one when you expect it.
Laurie | Maryland
Best Answer11-16-2024 05:02
11-16-2024 05:02
Best Answer11-17-2024 12:22
11-17-2024 12:22
@RebPet Product Experts aren’t employees. We are knowledgeable, experienced users who like to help others. Like I wrote, treadmill distance accuracy is difficult for other brands, not just Fitbit. My goal is to help you get the most from your workouts.
Laurie | Maryland
Best Answer11-17-2024 13:38
11-17-2024 13:38
