12-08-2023 20:09
12-08-2023 20:09
Hello!
My Sense 2 will not track SpO2. Anyone else having problems with this? Read in a review that you had to use Fitbit's own clock display to make it work.
By the way, it is very annoying not to be able to test this, as SpO2 is ONLY measured when you sleep. Then it takes a LONG time to troubleshoot and try different settings when you have to sleep before you get to test the changes you make before you fall asleep. It's pointless, isn't it? 🙂
And why couldn't SpO2 be measured, for example, every 15 minutes around the clock in addition to the fact that manual measurements can be made when you want a measurement? The sensor is there...so why does it only track when you sleep? Could the sensor be worn out? 🙂
Any ideas?
Regards
12-24-2023 10:52
12-24-2023 10:52
Do you have SpO2 enabled @RealEasterBunny
Are you seeing other advanced sleep details. Is your sleep at least 3 hours uninterrupted?
