Hello together,
I would like to ask if somebody is facing the same issue, where I'am not able to setup a device lock.
I'am on the latest version of the androind app with the latest firmware also. (60.20001.184.52)
While I'am suposed to enter the 4 digit PIN code Iam able to enter only the 1st digit where the cursor does not move to the second digit in the code, so I can't complete the PIN.
I have reinstalled the app, and also removed and added the watch again in the app.
Any suggestions please?
Thank you,
Beldo
Best AnswerBeldo,
Try adding the app on another device and try again. I couldn't get it to work on my samsung s8 no matter what i did. I tried on the s10 that i am transitioning to and it worked first try. The bonus is that it also updated the app on the s8. I can only guess that we were experiencing a glitch between the fitbit app and certain phones. Hope this helps.
Roger
Best AnswerBeldo,
Roger
Best AnswerHello Roger,
Thanks for the hint.
Indeed I've used my iPad to setup the PIN.
Seems it's a issue of the Android app on some devices.
Cheers,
Beldo
