11-24-2022 04:25
11-24-2022 04:25
Hello together,
I would like to ask if somebody is facing the same issue, where I'am not able to setup a device lock.
I'am on the latest version of the androind app with the latest firmware also. (60.20001.184.52)
While I'am suposed to enter the 4 digit PIN code Iam able to enter only the 1st digit where the cursor does not move to the second digit in the code, so I can't complete the PIN.
I have reinstalled the app, and also removed and added the watch again in the app.
Any suggestions please?
Thank you,
Beldo
Best Answer11-27-2022 08:42
11-27-2022 08:42
Beldo,
Try adding the app on another device and try again. I couldn't get it to work on my samsung s8 no matter what i did. I tried on the s10 that i am transitioning to and it worked first try. The bonus is that it also updated the app on the s8. I can only guess that we were experiencing a glitch between the fitbit app and certain phones. Hope this helps.
Roger
Best Answer11-26-2022 07:49
11-26-2022 07:49
Beldo,
I can't give you a solution, but I can tell you you're not the only one experiencing this. Please share if you figure it out. I tried to contact fitbit for help but they were not helpful.
11-27-2022 08:42
11-27-2022 08:42
Beldo,
Roger
Best Answer11-27-2022 09:01
11-27-2022 09:01
Hello Roger,
Thanks for the hint.
Indeed I've used my iPad to setup the PIN.
Seems it's a issue of the Android app on some devices.
Cheers,
Beldo
