02-24-2023
09:32
12:15
02-24-2023
09:32
12:15
On wrist call is not working. I have to fix it all the time and app is requesting a restart of the phone... At least i am doing that 3 times a day and it is not working.
Best Answer02-25-2023 12:16 - edited 07-29-2023 04:16
Hi there, @Joyce.ch. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Sense 2 prior to posting here and for the image attached.
As @Guy_ has recommended, I'd like to suggest some steps that work for users who own a Huawei phone, however, since you own an Android device I'd still suggest you to try them:
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
20:32
09:05
02-24-2023
20:32
09:05
Hi @Joyce.ch - this issue may be related to the type of phone you have and it's settings.
If you have battery optimization on (by default possibly) it can disable the Fitbit App or associated services from running in background in which case it can't sync or provide notifications to the watch.
Incidentally does logout and swiping off the active Fitbit app window and login enable sync?
