12-14-2023 09:49
12-14-2023 09:49
The last while when I open my Fitbit app getting up in the morning, a red circle with a exclamation mark shows next to Sync now, causing the fitbit app not to Sync to my Sense 2.
However, I went into Settings and selected Lock screen notifications. I them turned off the Keep Show content when locked feature. This was done to solve another issue, which was solved.
It appears to keep the red circle from showing on the Fitbit app.
Its been three days and the red circle has not appeared. Keeping an eye on it.
Hope this helps with any other user having the same problem.
12-15-2023 18:04
12-15-2023 18:04
Usually that circle means that your BT needs to be turned on to sync any information to the Fitbit app.
one cruise ship at a time!
