Sense 2 started flashing the logo then a red x
My sense 2 started flashing the logo then a red x. I have done a reset and set it back up in the app and it immediately started flashing and then the red x. What do I do and how do I contact customer service?
Moderator edit: clarified subject.
4 REPLIES 4
A warm welcome to the forums @Linmar2
Thank you for providing the information about this difficulty with your Sense 2. Thank you for trying to fix it on your own.
Please give it a try following the steps listed below:
1. Sync the device in the Fitbit app.
  • From the Today tab in the Fitbit app, tap Devices.
  • Chooose the Sense 2.
  • Tap Sync Now.
2. Check for available Firmware updates.
  • With the Fitbit device nearby, open the Fitbit app (make sure the Fitbit device is charged).
  • Tap the Today Tab > Devices > your device.
  • Tap Update (This option only appears if an update is available).
Follow the on-screen instructions: Keep the Fitbit device close to your phone during the update. When the update starts, a progress bar appears on the device and in the Fitbit app until the update is complete.
3. Charge the device:
Double-check the connection: Ensure secure connection to the charging cable and that the cable is plugged into a working USB port (computer or UL-certified wall charger).
If these steps don't work:
4. Restart the device: Keep in mind that your data won't be deleted: How do I restart my Fitbit device?
5. Changing the clock face via the Fitbit app can sometimes resolve the issue:
  • Open the Fitbit app.
  • Choose Device Settings.
  • Navigate to the clock face options and try selecting a different clock face.
having same issue  was working great   help tried all the stuff
Welcome to the forums @aguyinthe
Thank you for sharing the inquiry about this issue with your device.
Could you please confirm that you tried performing the steps as listed above?
Do you see green lights on the back of the device or do you feel vibrations when trying to restart?
no green i do have vibrations
